Re: Not enough pickle on my fork
not aware that they are threaded in, i have good luck with a hammer, I work on large tractors for a living, I rarely use any kind of seperating tool. take a hammer and smack the spindle where the tapered part of the joint goes in. what this does is shrinks the area that the bj is in and forces it out by the taper. like said i RARELY have to use a separating tool. they tear grease sleeves and I generally do not like them. sometimes you have to use something, but usually they are junk anyway, and who cares then, beat em out by the threads if you have too.
I really doubt they are originals, possible i guess, but i doubt it.
is this a 4x4 truck? if not that gives you more room to play around, as the shaft isn't there, you got access to the heat wrench? it is a very good motivater, melt it out if you have to, just put as little heat as possible into the control arms. focus all your heat on the bj if you can, as in BALL JOINT, not bj as in I know what most of you are thinking.....
delete that last question, you already answered it, yes it is 4x4 you plainly said that, just didn't pay attention, sorry
10 credit hours away from John Deere master certified tech.
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while. So schooling there too....
Also couple years exp in GM and some GM training
01 Malibu, 4dr
1990 Acura Integra GS 5spd FOR SALE
98 TJ 4in lift 33's 4.10s 2.5 5 spd FOR SALE
05 K truck. SOLD
Wife's truck. 04 T (trailblazer) ext. 5.3 4l65
got the piston slap.....
