Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-02-2009, 02:04 AM   #1
nichols45
nichols45 Normal reputation
Engine Quit on Hwy
I have a 93 Camery LE 5SFE 2.2L I was driveing down the Hwy at 65 MPH and the engine just shut down. Now it will not start. I check the codes as got a DTC-24. I changed the battery out to see if the alt wasen't working and drained the battery but have the same problem. The engine turns over a several times and sounds like it wants to satrt but will not kick off. Any suggestions?
nichols45 is offline   Reply With Quote
Old 07-02-2009, 09:26 AM   #2
Mike Gerber
AF -Advisor
Mike Gerber Normal reputation
Re: Engine Quit on Hwy
In my experience when a car quits suddenly while running, the 2 most common causes are a broken timing belt and a broken fuel pump. To check for a broken timing belt remove the distributor cap and have someone crank the engine over while you watch to see if the rotor is turning. If the rotor turns, the timing belt is still intack. If not you know you have a broken timing belt. To check for a bad fuel pump, remove the large tube leading to the throttle body. Spray some carb cleaner liberally in to the throttle body and reinstall the tube. Try to start the car. If the car now sputters and trys to start, you know the car was not previously getting fuel. Check the fuel filter, the fuel pump relay and then the fuel pump.
Mike
Mike Gerber is offline   Reply With Quote
Old 07-02-2009, 09:53 AM   #3
dtownfb
dtownfb Normal reputation
Since the engine suddenly stopped in the middle of driving, it's probably an ignition problem. Ignition issues can take longer to diagnose because the symptoms often point to a fuel related issue (fuel pump, FPR, fuel filter, etc.). I would think a bad fuel pump would sputter for a bit before the car died. I had ignition problems with my 2000 Olds Intrigue. Took me two months (and numerous stallings) to diagnose it as a bad ignition switch.
Here's a forum question from an owner of a 1993 Camry whose car has the exact problem that you are describing: sudden stalling, cranking but no starting. http://en.allexperts.com/q/Toyota-Re...y-ignition.htm
It points to a problem with the ignition module. Ignition issues will not throw a code, only emission/transmission issues. Your DTC-24 is an "Intake Air Temperature sensor signal".
Here's the full list of Toyota OBDI DTC codes: http://www.troublecodes.net/Toyota/
Good luck.
dtownfb is offline   Reply With Quote
Old 07-02-2009, 10:27 AM   #4
Airjer_
Airjer_'s Avatar
Airjer_ Normal reputation
I'd check the timing belt as well.
Airjer_ is offline   Reply With Quote
Old 07-02-2009, 03:49 PM   #5
nichols45
I checked the timing belt and it is still turning. Would a belt jump a notch or two to causethis problem? I will check the fuel pump next.
Old 07-02-2009, 06:15 PM   #6
Mike Gerber
AF -Advisor
"Would a belt jump a notch or two to causethis problem?"
It's a possibility, but not one of the most common things to happen.
Mike
Old 07-07-2009, 11:32 AM   #7
jdmccright
The RustBuster
jdmccright's Avatar
jdmccright Normal reputation
Send a message via MSN to jdmccright
There's a third common cause, especially for this Gen Camry...dead ignition coil. They are housed inside of the distributor cap. Check and replace according to the sticky manuals at the top of this forum. Even if it checks out as barely good according to the specs, it isn't. Hope this helps!
Current Garage:
2003 Pontiac Vibe 1.8L AWD
2003 GMC Envoy XL (aka "fat-a$$") - K&N air filter, otherwise stock.
1995 Chevrolet C2500 2wd, 5.7L - K&N air filter, otherwise stock...my weekend hauler.
1992 Toyota Camry LE 2.2L - K&N air filter.
Vehicle History:
2004 4.7L Dakota Quad Cab 4x4
1996 GMC Jimmy 4wd
1992 Chevrolet S10 Ext. Cab 4.3L
1995 Honda ST1100...my first (and only) new vehicle.
1980 Yamaha XS400
1980 Mercury Bobcat...my first car.
jdmccright is offline   Reply With Quote
Bookmarks
Google
Web AF
