Fuel filldavidveum 07-01-2009, 11:59 PM "04 suburban Z71 it took me 10 minutes to pump 16 gallons of fuel. It sounds like a vent issue (whistles down - then I can pump again) GMMerlin 07-02-2009, 06:46 AM If your vent valve is plugged, this could be the cause j cAT 07-02-2009, 10:43 AM "04 suburban Z71 it took me 10 minutes to pump 16 gallons of fuel. It sounds like a vent issue (whistles down - then I can pump again) the fuel fill pipe is a hose in a hose..the inner hose is were the fuel travels the outer hose is where the vapors vent... if this hose is twisted/distorted it will prevent vapor from venting...give the hose a massage to remove any distortions... it is possible the tank may need be droped and this hose properly installed...this has been reported after fuel pump repairs made.. buckshooter1 10-10-2009, 07:34 PM I had the same problem on my 05 it was the tank vent valve it is located on the back of the vapor canister. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
