Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Corolla/Matrix/Voltz
Old 07-01-2009, 08:00 PM   #1
dtlowrider
dtlowrider Normal reputation
Question 2003 Toyota Matrix Guages Are Out.
I have a 2003 Toyota Matrix, after getting out of work I started my car and all 4 cluster lights are out, The Fuel, RPM, Speedometer, and Temp. The seat belt sign works, door open sign works, all the notice lights work but none of the gauges. Before I go to the junk yard or dealer and go buy a new cluster, any advise would be great. Also how do i take the cluster out, when i take the cover off all I see is one screw on top of the gauges, i know there has to be more just hoping i dont have to take off the dash..
dtlowrider is offline   Reply With Quote
Old 07-01-2009, 10:25 PM   #2
roadrunner2
roadrunner2 Normal reputation
Re: 2003 Toyota Matrix Guages Are Out.
Before buying anything, check out the fuses. Under the drivers side dash and underhood drivers side).
The problem with doing nothing is not knowing when you're finished.
roadrunner2 is offline   Reply With Quote
Old 07-02-2009, 09:45 AM   #3
dtlowrider
Yea i checked checked that out, the fuse looked good but to be safe i replaced it just incase and still nothing. Should have mentioned that. Even took my test light out to make sure but fuse is all good.
Old 07-02-2009, 09:19 PM   #4
roadrunner2
Hmmmm, is the interior courtesy light dimmer switch turned right down? Sounds silly, but sillier things have happened.
Looking at my Haynes repair manual for my '04 XR, it describes how to remove the cluster and module but it's too much to type here.
If you decide to do your own repairs it'll be worth your $20 to buy it. Haynes manual number 92037.
Old 07-02-2009, 10:12 PM   #5
dtlowrider
Ya the gauges dont even move at all so ya, ill have to check that book out and I guess start calling some junk yards to see if they have a cluster for me.. Thanks for your help... O ya one more question, do you know if i have to go to toyota to program the new cluster?? THanks again for all your help
Old 07-03-2009, 03:45 PM   #6
roadrunner2
Sorry, don't know about programming a cluster.
Because of that, I'm not sure if getting a 'new' used one from a wrecker is wise. There will be a difference in the odometer reading for one thing, although I know these can be jacked with too.
Old 07-03-2009, 06:36 PM   #7
dtlowrider
Yea true, ill call toyota and see proally wont tell me the truth though to get me to buy one of theres...thanks though
Old 07-10-2009, 12:32 PM   #8
jdmccright
The RustBuster
jdmccright's Avatar
jdmccright Normal reputation
Send a message via MSN to jdmccright
I have no idea about your particular cluster, but you may be able to have it repaired. There are sellers on eBay that specialize in gauge cluster repair...bulb check, gauge needle servo replacement, LCD check/replace, etc. You keep the original cluster so no odo reprogramming is needed. I've had the service performed on my Envoy's cluster and from the gripings of the wife it sounds like the same may be happening to the Vibe now...funny, she was driving the Envoy before too, hmmmm.... I just got it back in the mail so can't report on success but you may look into it as an option if you can spare you car being down for a week. Good luck!
Current Garage:
2003 Pontiac Vibe 1.8L AWD
2003 GMC Envoy XL (aka "fat-a$$") - K&N air filter, otherwise stock.
1995 Chevrolet C2500 2wd, 5.7L - K&N air filter, otherwise stock...my weekend hauler.
1992 Toyota Camry LE 2.2L - K&N air filter.
Vehicle History:
2004 4.7L Dakota Quad Cab 4x4
1996 GMC Jimmy 4wd
1992 Chevrolet S10 Ext. Cab 4.3L
1995 Honda ST1100...my first (and only) new vehicle.
1980 Yamaha XS400
1980 Mercury Bobcat...my first car.
jdmccright is offline   Reply With Quote
Bookmarks
Google
Web AF
