No idler arm on that type of front end,
checked it with the level and on level ground the tire's almost center bubble, back the truck up about 10 feet and the top of the both tires each go in about 2 1/2 inches and the bottom of each tire goes out about 2 inches.
have already replaces the I-beam bushings, 1 upper ball joint, a tie rod end and double checked the wheel beaings to make sure they are tight.
have had 3 other people looking under it when moving it forward and back and no one can see anything move.
also note, when driving it goes down the road straight, does not jump when hitting bumps or pot holes,
anyone have any other ideas
