Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Buick > Park Avenue
Old 07-01-2009, 04:32 PM   #1
C man
C man's Avatar
C man Normal reputation
GM Oil Life Moniter
Just wondering does the OLM reset if you disconnect the battery. I have had mine come on. I usually change my oil at 3.5k-4k intervals so I reset it but most of the time I disconnect my battery or something but I never knew if it reset it or not.
But now I want to keep my oil in until the OLM light comes on to see how long it would take before I needed to change the oil. Most of the things that happens have happend to me. Except for the intake mainifold issue which I'm waiting for it failure. I have put 47k on it since I had it and it got changed out some time in 2003 or that at least how old the intake manifold is. Also I haven't experienced the CPS sensor problem or fuel pump problem.
Basically I'm planning on spend as little money and time as possible since this has been a reliable car(put 1k miles on it last weekend) but I don't plan on neglecting it. I just don't want to over maintain like I do sometimes. I still plan on doing a transmission fluid change and fuel filter change in September once the summer heat passes.
Just trying to maximize cost of ownership and save some and maintain it properly also.
95' PARK AVENUE 161,000 MILES
Warning : Listen at your own discretion
C man is offline   Reply With Quote
Old 07-01-2009, 08:24 PM   #2
maxwedge
A990 racer
maxwedge Normal reputation
Re: GM Oil Life Moniter
Stepping on the gas pedal, engine off, to the floor 3x in 5 seconds should reset the system, if you have a driver info system there is a reset in there. Do not disconnect the battery this causes relearn situation that is unecessary.
maxwedge is offline   Reply With Quote
Old 07-02-2009, 02:02 PM   #3
C man
C man's Avatar
Sorry, I was not implying that I didn't know how to reset the OLM. Mine is a button in the glove box and I have to hold it with the key on for 5 seconds until it flashes. I was asking does it still retain information like some of the computers in a car if you disconnect the batttery which I had to do a couple of times since my last oil change.
Also I was wondering about opinons on the OLM.
Old 07-02-2009, 03:43 PM   #4
maxwedge
A990 racer
GM engineers have developed an algorythm that is pretty good regarding oil change intervals. I believe the OLM will not loose it's memory for a 5 minute disconnect, not sure though.
Bookmarks
Google
Web AF
