Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Nonspecific
Old 06-30-2009, 11:14 PM   #1
aartod
aartod Normal reputation
fuel pump issues!
I have a fuel pump issue and I was wondering if anyone has had a problem like this before or knows anything about it. The car has a 86 4.3l tbi v6 and has a in-tank fuel pump. It wasent starting so when I was checking for fuel I disconnected the fuel line at the throttle body and cranked over the car and fuel spurted out for about a second or two then it stopped flowing alltogether... so I tried it again and the same thing happened over and over. So then i checked to see if there was power getting to the fuel pump all the time not just during the intial start-up--- and there was... I unplugged the connector by the tank and put a test light on it and there was constant power while cranking. So if there is power getting there and the pump is not pumping enough then I figure it needs to be replaced... But I have never see this before, I have seen them not work at all, or not enough pressure, but not a big spurt and then nothing- everytime! What do you think?
aartod is offline   Reply With Quote
Old 06-30-2009, 11:39 PM   #2
Scrapper
Scrapper Normal reputation
Re: fuel pump issues!
it sounds like you do need a fuel pump but i'd put it on a guage and see how many psi it's at and see how much psi it's supposed to have since it's a tbi.
Scrapper is offline   Reply With Quote
Old 06-30-2009, 11:58 PM   #3
aartod
I dont have a gauge... It think the older tbi system only used about 10-12 psi..
Old 07-01-2009, 01:35 AM   #4
Airjer_
Airjer_'s Avatar
Airjer_ Normal reputation
I would backprobe the grey power wire with the connector plugged in. Make sure there is 12 volts there all the time with a voltmeter. If voltage drops there is another issue!
Airjer_ is offline   Reply With Quote
Old 07-01-2009, 09:27 AM   #5
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
You need a gauge to test pressure.
Can not tell by the squirt how much pressure it has.
Parts places and tool dealers have gauges for sale and some parts places loan/rent gauges.
Check that pressure and post back pressure readings.
MT
MT-2500 is offline   Reply With Quote
Old 07-01-2009, 09:51 PM   #6
aartod
Well after the intial spurt of gas there is no gas flowing out of the fuel line I dont think I need a gauge to measure 0 psi...
Old 07-02-2009, 07:17 AM   #7
rhandwor
rhandwor Normal reputation
Run a temporary set of wires back to the fuel pump this will eliminate a wiring problem otherwise buy a new pump.
A loose fuel pump ground will cause many fuel pump problems.
rhandwor is offline   Reply With Quote
Bookmarks
Google
Web AF
