Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 06-30-2009, 05:02 PM   #1
Emmitt101
Emmitt101 Normal reputation
Another Tranny Problem
I have the P1870 code and I know what causes that but now it seems I have a new problem. Was driving on the interstate the other day and looked in the rear view mirror and saw smoke pouring from the rear. Pulled over and saw tranny fluid dripping on the crossover pipe. Opened the hood and it seemed like the fluid was coming from the little "valve" beside the dipstick. After a few minutes I started it up and no more fluid anywhere. Thought all was ok, but the same thing happened again today. Is it possible that the fluid is being pushed out from that valve? Haven't added any fluid so I know the fluid level was good. Any ideas?
Jeff Isley
Emmitt101 is offline   Reply With Quote
Old 07-01-2009, 09:18 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: Another Tranny Problem
What year and what transmission and how many miles on it?
The root problem on a 1870 code is internal pressure leakage/slippage.
Lot of band aids for it but the perment cure is a transmission rebuilt.
I do not know of any valves by dip stick.
Post a picture or take a close look at the leak.
Clould be a cooler line or TV cable or servo or dipstick seal or bad dipstick.
Is the transmission slipping or heating up.
If getting hot some will blow fluid out dipstick or vent tube?
Has filter and fluid ever been serviced?
Any other codes besides 1870?
MT
MT-2500 is offline   Reply With Quote
Old 07-01-2009, 12:29 PM   #3
Emmitt101
1996 Blazer LT 4l60e Transmission Changed fluid and filter last year
Old 07-01-2009, 12:31 PM   #4
Emmitt101
The part in question is actually strapped to the dipstick tube near the top.
Jeff Isley
Old 07-01-2009, 02:09 PM   #5
MT-2500
AF - Advisor
MT-2500's Avatar
There is no parts on dip stick tube.
Could it be the hold in/down brace that goes to engine/transmission mount bolt?
Can you post a picture?
MT
Old 07-02-2009, 08:02 AM   #6
b1lk1
b1lk1 Normal reputation
Possibly the vent for the transfer case? If that is leaking out fluid that is a whole different issue than any tranny problems.
1999 GMC Jimmy SLS (these trucks sure suck the life out of your wallet, LOL!)
Cold Air intake (eBay special with homemade heat sheild)/Throttle plate modded
2" Suspension lift (rear springs/front torsion crank)/1 1/4" read wheel spacers
b1lk1 is offline   Reply With Quote
Old 07-08-2009, 02:17 PM   #7
Emmitt101
Here's the pic. See the hose connected to the dipstick tube.
Old 07-08-2009, 06:22 PM   #8
MT-2500
AF - Advisor
MT-2500's Avatar
It is a vent hose for transmission or front rear end.
Trace it down to other end.
If it goes into the center upper part of transmission it is a transmission vent.,
Make sure transmission fkluid leve is good.
If it is blowing out transmission vent and fluid is not over full the transmission may be sliping and getting hot and blowing out fluid.
Which is the main cause of the code you have.
MT
Bookmarks
Google
Web AF
