Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 06-30-2009, 04:43 PM   #1
ChrisinVT
ChrisinVT Normal reputation
Rear coilover spring rate ?'s
I tow alot with my Lumina, and recently the rear struts have bitten the dust. The rear leaf spring is starting to devolop some sag from towing also (currently about 1-1.5"). I'm going to build a coilover kit to use as helper springs in the rear of my car.
I'm planning on keeping the monoleaf, and adapting the struts to coilovers. I'm looking into getting a low springrate (I'm thinking 110, 130 or 150) since these will be used as "helper springs" to eliminate sag and sway when towing a trailer. (I'm also thinking about pulling a swaybar off a Euro to help stiffen up the rear a bit more also.) Most guys seem to run 250lb springs when doing a full monoleaf delete, but since I'm keeping the [saggy] monoleaf I'm thinking I should go with softer coilovers.
These are the parts I'm looking at:
Just looking for some input on what rate springs would be best for my application. I don't want to go too soft and defeat the whole purpose of doing this, or go to hard and have to swap to something softer.
^---------- Click for epic pics -----------^
  • 1987 2.8L 2D GMC S-15 4WD X-Cab Anti-Bro Truck
  • 1992 3.1L 4D Chevy Lumina RallySport
ChrisinVT is offline   Reply With Quote
Old 06-30-2009, 10:41 PM   #2
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
jeffcoslacker Normal reputation
Re: Rear coilover spring rate ?'s
Just a question...are you sure it's not missing some of the bushings that provide the arc to the leaf?
Monoleafs usually won't sag...but they do like pop bushings out and lose arc...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
jeffcoslacker is offline   Reply With Quote
Old 07-01-2009, 08:36 AM   #3
ChrisinVT
Yup, everything's there. Even pulled the rubber shit off the ends and put the polly pucks in there.
Bookmarks
Google
Web AF
