1997 Jimmy. Something is still leaking down inside the plenum. Fuel pump and filter is new. Fuel pressure gauge hits 64 and then bleeds back to 40 in about 1 minute. Then it goes to 0 in about 4 minutes.
Does anyone have a diagram of the fuel pressure regulator and how it seats into the metering body? I replaced the fuel pressure regulator but I may have messed up the o-rings or the screen.
Also, do the metal fuel lines going into the metering body need o-rings? Mine had one metal washer on the pressure line going in ...
Also, do the metal fuel lines (the ones bracketed together) need o-rings where they connect to the lines running to the back of the truck?
Here's a picture of the inside of the plenum. You can see washing by the 6, 5, and 3 port. I replaced the #3 injector because the plastic looked bad. The other injectors/tubing/poppet looked fine and seated fine.
When I pressurize the system with the plenum off, I don't see or hear any visible leaks.
Should I just do a new o-ring kit, put a new o-rings on each injector, and see what happens ($25)? Should I try another fuel pressure regulator ($65)?
maybe the poppets are leaking when under engine load ??
