Re: Starter turns for only a couple of seconds
Weak battery or corroded/loose connections at battery or starter- Inspect/clean connections and have battery load tested. Try jump starting using jumper cables and another vehicle. If it cranks ok then this is a likely source of the problem.
Worn starter - Remove and have tested or just replace
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
**DIYer and multiple automotive forums junkie for years. Air Force career in aviation electronics.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan / 94 Camry
