Re: Engine and Transmission Compatibility Issues
The ignition cylinder has a built in resistor, the PCM has to see the correct resistance, if it doesn't, it won't allow the fuel injectors to fire. This makes it take a bit over 30 minutes to hotwire the car to steal it, I guess GM figured someone would come along and call the cops in this time(?). To reset the code, try to start the engine. Release the key to 'on' and wait 10 minutes. The 'security' light will go off after about 10 minutes. When it does, turn the key to off, then back on, wait 10 min, off, on, wait 10 min, off, try to start. It should start this time. With DRL, you'll probaby want to disable the headlights or put the battery on a charger unless your battery is pretty good.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
When you buy something... a bottle of pop for example, who gets the profit from it and what do they do with it? Maybe your money's going to groups that want to hurt you. I think everyone should do a search for things they purchase regularly "____ supports". Might just find a company you won't buy stuff from anymore.
