Originally Posted by j cAT
check the vacuum line on the fuel regulator,,,not too sure with your vehicle but on the newer engines the regulator diaphram ruptures and then fuel is sucked into the engine causing a rich mixture which will destroy the cat converters...
think he got this one right, also the 4.3 fuel systems have a "spider" assembly, the regulator assembly and the fuel injectors are all one unit, the said above regualtor is also on this assembly, the upper intake has to come off to get to it, don't worry, a 15 minute job for someone who wrenches alot, cant see anymore than 45 for someone who doesn't. If any of the above is leaking you will run lean and have black smoke. Do you have any codes?
With 283k and the resultant carbon in the upper end, I am sure you would see "tracking" under a leak where the cool fuel from the leak has steam cleaned the inner parts of the intake.
Once again any codes? No reason to thorugh parts at it. Usually when the regulator leaks out it is hard to start if it sits for any length of time, because the fuel pump has to reprime the system, these things will not run unless they have adeqaute fuel pressure.
