How to install An tachometer (RPM) on an Mirage I found it on a websideyoungsense 04-02-2003, 08:51 AM I lost my tachometer instructions. What is the wiring color code? Red: +12 volts with the key in the "on" position Black: Ground Blue or White: Dash lights Green: Tach signal from engine Where do I connect the green wire? On a classic distributor and coil ignition system, the green wire connects to the negative side of the coil. Now that most cars have some sort of electronic ignition, coils (and even distributors) are becoming increasingly rare. On newer cars, you'll need to connect to a tach signal on the ignition module, engine computer or distributor. SuperTach Application Guide for Mitsubishi Mirage -------------------------------------------------------------------------------- SuperTach Applications | Mitsubishi | Mirage MODEL 1.YEAR ENGINE 2.SIZE DEVICE 3.NAME DEVICE 4.LOCATION WIRE 5.COLOR PIN ID TACH ADAPTER 1985-87 1.5L NEGATIVE SIDE OF IGNITION COIL TOP OF ENGINE WHITE N/A N/A 1985-88 1.6L TURBO NEGATIVE SIDE OF IGNITION COIL TOP OF ENGINE WHITE N/A N/A 1988 1.5L NEGATIVE SIDE OF IGNITION COIL TOP OF ENGINE BLUE/WHITE STRIPE N/A N/A 1989-90 1.5L NEGATIVE SIDE OF IGNITION COIL TOP OF ENGINE WHITE N/A N/A 1989 1.6L TURBO IGNITION COIL PACK TOP OF ENGINE WHITE 3 N/A 1990-92 1.6L TURBO POWER TRANSISTOR REAR OF ENGINE WHITE 4 N/A 1991-92 1.5L NOISE FILTER ON FIREWALL IN ENGINE COMPARTMENT WHITE 1 N/A 1993 1.5L DISTRIBUTOR ASSEMBLY PASSENGER SIDE OF ENGINE COMPARTMENT WHITE 11 N/A 1993 1.8L DISTRIBUTOR ASSEMBLY PASSENGER SIDE OF ENGINE COMPARTMENT WHITE 11 N/A 1994-95 1.5L DISTRIBUTOR ASSEMBLY PASSENGER SIDE OF ENGINE COMPARTMENT WHITE 12 N/A 1994-96 1.8L DISTRIBUTOR ASSEMBLY PASSENGER SIDE OF ENGINE COMPARTMENT WHITE 12 N/A 1996-00 1.5L DISTRIBUTOR ASSEMBLY PASSENGER SIDE OF ENGINE COMPARTMENT WHITE 2 N/A 1997-01 1.8L IGNITION FAILURE SENSOR DRIVER'S SIDE OF ENGINE COMPARTMENT WHITE 2 N/A I hope you guy's understand it and It will help you guy's . I haven't test it jet for my car am waiting for some stuff for performace my car an then am going to install the tachometer for my mirage 1997 without tachometer. :) SierraK1500 06-14-2004, 05:59 PM Is this the white wire coming from the distributor? On a 1996 Mirage the coil is integrated in the cap. Thanks John Automotive Network, Inc., Copyright ©2012
