Re: hella overheating prob
Are you using the fan switch from the original engine, or is it a different one? It sounds like your previous issue was a bad switch, so if it's the same one just replace it. And now that you've replaced the radiator and hoses, air definitely got in the system, so make sure there aren't any air pockets still in there. If all else fails, you could try a "bandaid" fix and use a bottle of Water Wetter, or a lower temperature thermostat.
