removing bezel?
Google
Web AF
ello
06-27-2009, 11:05 PM
Lol hello everyone.
I have the noobiest question ever. I have an old 96 Toyota corolla and I cannot find any help on removing the bezel to be able to remove the deck installed. I finally found 2 clips at the very top right of the bezel, but it doesn't seem to pop off using a flat screwdriver (not prying too hard as I dont want to break the flimsy plastic :P) Does anyone know how to get the bezel off here to remove the deck installed?
Here is pic I found of what the TOP PART of the bezel looks like:
http://memimage.cardomain.com/ride_images/1/3349/2021/8371010007_large.jpg
Thank you very much,
-ello
PaulD
06-28-2009, 08:13 PM
check underneath, mine has two screws under the bottom. Also pull the clock out, there is often one under that.
ello
06-28-2009, 10:14 PM
I took out the two screws and still cant get that piece to budge. How did you remove the clock without removing this plastic piece?
PaulD
06-29-2009, 07:59 PM
mine just pops out with a little pressure, but it's a honda - maybe it's different.
Perhaps you should ask this in the Toyota section, they would be a little more familiar with them than I would.
ello
06-29-2009, 10:10 PM
what part do you apply the pressure to, to get it to start to pop off.
'97ventureowner
06-29-2009, 11:13 PM
I'm moving this to the Toyota forum for additional responses.
PaulD
06-30-2009, 06:26 AM
my panel is angled and so the bottom of the clock has a flat spot that I can press against to pull it out. Try gently prying it out with a flat tip screwdriver.
Google
Web AF
