Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 06-27-2009, 01:43 PM   #1
billindelicato
billindelicato's Avatar
billindelicato Normal reputation
Keyless Entry???
I have my 98 blazer ls and was told by the previous owner that it has keyless entry but no remotes via the factory...how can one actually determine this to be true? i would love to have keyless entry without having to spend a fortune.
1998 Chevy Blazer LS 4x4
1996 Ford Dunderbird LX 3.8L
billindelicato is offline   Reply With Quote
Old 06-28-2009, 10:56 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: Keyless Entry???
Get a oem factory remote and see if it will program and work on it.
MT
MT-2500 is online now   Reply With Quote
Old 06-28-2009, 03:00 PM   #3
billindelicato
i wouldnt even know where to begin with programming it...was gonna pick one up from ebay but they could be a bit dodgy if you know what i mean.
Old 06-28-2009, 03:24 PM   #4
b1lk1
b1lk1 Normal reputation
Check the RPO code list on the glovebox. If you have code AU0 and/or AU5 then the truck should be factory equipped for keyless entry. If Ebay scares you then you are gonna need to go to the dealer and they will probably have to not only program the remotes but even possibly reprogram the BCM for it to work right as well. You could technically get a remote or two from the local wrecking yard and have those programmed to your truck as well.
1999 GMC Jimmy SLS (these trucks sure suck the life out of your wallet, LOL!)
Cold Air intake (eBay special with homemade heat sheild)/Throttle plate modded
2" Suspension lift (rear springs/front torsion crank)/1 1/4" read wheel spacers
b1lk1 is offline   Reply With Quote
Bookmarks
Google
Web AF
