Re: '97 Chevy Lumina Problems (possibly with alternator)
If the battery was out for a while, the idle memory was lost and will recover after some driving. If the volts light is still on, however, the alternator may be bad.
Sometimes there is a problem with the regulator's reference signal to the ECM, which can cause improper system voltage even with a healthy alternator...
You really need to get the output tested with the alternator on the vehicle. I like to test charging volts at the battery AND at the large charge post on the back of the alternator...if different, there's a burnt fuse link involved. Saves time and a lotta tail-chasing to test it both ways...
When you said the power steering went out, it made me wonder if that was simply the result of the motor dying, or if perhaps the belt is slipping under increased alternator load...did the tensioner seem strong when you took the belt off? Check for drag in other belt-driven accessories too....if something's dragging the belt down, alt output will be reduced...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
