Re: Continuing gasket problems?
Is there any smoke coming out the tailpipe? How bad was the leaking, how long was it like that. As for under the hood, the engine cannot smoke, it is essentially sealed. Is your exhaust manifold(s), y-pipe, are not leaking, and you see nothing coming out the tail pipe when the eninge is running, chances are it is just spilled fluids buring off.
When taking the oil filler cap off while the engine is running, you shouldn't really see any smoke/air escaping. The engine should kind of lower its idle a bit, but it should be alright. If your seeing a lot of pressure out the oil filler cap, you either have a clogged pcv valve and or pcv system, or have bad blow-by.
