Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 06-26-2009, 07:37 PM   #1
chevgirl
chevgirl Normal reputation
can anyone help?
Hi I just bought a 94 s10 with a 4.3 4x4 standard and having wayy to many problem with it
the guy put a new motor in the truck and told me it was a matching motor
it didnt have the power It should have so I thought it just needed new spark plugs ext no biggie I can deal with that
ok so I changed spark plug and found out he put the old spark plug in the new motor which ended up being too short as this was motor is newer at least a 96 not sure on year tho
so new spark plug and wire.. got right in there and it only has one ani knock sensor hooked up other ones just dangling there GESHH ok were is the other sensor at the one on the passengers side is in but not the other one???
the only other problem is that is just has no power almost like the timing is off but I check it and its right on is there anything iam missing???
chevgirl is offline   Reply With Quote
Old 06-27-2009, 08:48 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: can anyone help?
Sounds like you need to find a good mechanic that knows what they are are doing.
MT
MT-2500 is online now   Reply With Quote
Old 06-27-2009, 01:09 PM   #3
chevgirl
already had to it to the local shop and they don't know what was wrong with it they couldnt even find were this lost knock sensors supposta be located at, and Iam not about to take it to the dealer cant afford that plus is a 2 hour drive to the closest dealer. just hoping someone might be able to help a little on here .
Old 06-27-2009, 02:04 PM   #4
dozer1
dozer1 Normal reputation
maybe the catylatic converter
dozer1 is offline   Reply With Quote
Old 06-27-2009, 02:53 PM   #5
chevgirl
doesn't have one anymore I took it out and put all new exhaust in
Old 06-27-2009, 03:39 PM   #6
MT-2500
AF - Advisor
MT-2500's Avatar
On the timing set the base time with the EST timing wire disconnected.
If no cat the knock sensors are not going to help you.
About knock sensors would need to know your engine code and what year and make and model and engine code the replacement engine came from.
MT
Old 06-27-2009, 03:45 PM   #7
chevgirl
I asked the guy when I bought the truck were the motor was from and all he knew was it was a factory rebuild from Vancouver and it was a match to this truck. So the motor should be from a s10 and I do know it is at least a 96 because of the spark plug length
( longer then the one from the 94) the truck runs great just not the power just thought there might be something little that I've over looked
Old 06-27-2009, 04:42 PM   #8
MT-2500
AF - Advisor
MT-2500's Avatar
Check base timing and for codes.
MT
Old 06-29-2009, 06:16 PM   #9
chevgirl
ok I borrowed a code reader and it came up with engine code error that all it said
I tried changing my throttle sensor and it help a bit not so jumpy when you change gears re did a timing check and its right were it should be only thing I can think of is wrong computer ?? might take it to the guy next town over that recode the computer or put a new one in???? only thing left that I can think of
only ever had one truck stump me this much and that a blown small block with carb issues lol
Old 06-29-2009, 06:51 PM   #10
MT-2500
AF - Advisor
MT-2500's Avatar
Did you go threw the base time procedure by disconnecting the EST bypas wire?
What was the code no you got?
Did the new TPS sensor clear the code or does the code come back?
MT
Old 07-18-2009, 11:45 PM   #11
chevgirl
ok finally got PO'd enuf to take it to the dealer
they got a invalid engine error code they couldn't find out what it was or why
all this frustration over something not even a dealer can answer me lol
they said i could bring in it to do a complete check for about a grand and they'd check ever plug sensor ect or I could just leave it as it not hurting my truck lol
Old 07-19-2009, 07:00 AM   #12
MT-2500
AF - Advisor
MT-2500's Avatar
As in post 2 you need to find a good mechanic.
Even all dealers do not have factory trained tech's/mechanics.
If the dealer does not have them find a good repair shop or a good dealer that does.
It should not cost a grand to test everything out.
A couple of hrs by a good mechanic should do it.
MT
Bookmarks
Google
Web AF
