I would have a fuel pressure test done. Put a fuel pressure guage on the return line and make sure your fuel pressure is reading 16 - 23 psi. I had this issue once and I had a kinked hose in the return line, back by the rear wheel. I was getting 60 psi at the TB.
By the back wheel on the driver's side, there is a small rubber hose that couples the metal lines from the car body to the tank. These have been known to kink or plug up. Check this hose and make sure that it is in good shape. You can remove the return line at the TB and make sure air flows through it freely.
At only 180,000 miles, the compression should still be good enough in that car to run great, unless you have a valve or two going. You could always do a compression test also.
