No power when gas pedal pushed
kurtzk
06-26-2009, 12:35 PM
2002 Kia Sportage 4wd. Starts up and idles no problem, but when you push the gas pedal down, it bogs down, and literally goes nowhere. There are no codes. I have checked TPS, MAF, grounds. I even detached the exhaust pipe at the manifold, to check and see if it was a plugged converter, no dice. The injectors were cleaned, and timing belt replaced at 80,000 miles, and it has 96,000 on it now.
Any other ideas folks, before i give it to the boneyard?
coachwoz
06-30-2009, 08:28 PM
take it in some place and see if they can figure it out. Did you pull the intake and see if the butterflys moved
LMP
07-07-2009, 06:58 PM
.... Starts up and idles no problem, but when you push the gas pedal down, it bogs down, and literally goes nowhere. ..
this description would have been relevant of mine 2 years ago. spark plugs and plug wires returned it to normal. I did not have to change the coils.
