2001 1500,1992 c/k 1500..MOTOR SWAP HELPggoonnjja 06-26-2009, 12:26 PM ok i got a 5.3 votec and i wont to fit it in a 1992 c/k truck.How hard will it be ? ukrkoz 06-28-2009, 10:26 PM ok i got a 5.3 votec and i wont to fit it in a 1992 c/k truck.How hard will it be ? very. you'll have to move the whole entire engine management system along. do at your own risk. i spoke. ggoonnjja 06-29-2009, 12:27 AM i have it all including steering column and all dash, under carrage and gas lines will the motor fit ? ukrkoz 06-29-2009, 10:06 PM ok, this is how it works - or does not, as i came across quite a few troubled owners that attempted much less years difference swap - and failed. 2001 powertrain is controlled by ECM, TCM, and BCM. engine, transmission, and body. unless it all mates and matches, you are going nowhere,:nono: or going with lotsa trouble down the road. :banghead: so, if you say you have it all, meaning - powertrain AND engine management systems, then the rest of it is a question of welding skills, acetilane torch availability, couple sledge hammers, prybars, and maybe few suspension brackets custom made. one or two very strong rednecks will be handy either. ggoonnjja 06-30-2009, 12:37 AM hahaha... ok i have a 2001 1500 and its been wreaked i have every thing that i need to make it work, but you anserd my ?. i dont have time to do all of that.... thanks.... it will fit in a 95 and up pretty easy,right? ukrkoz 06-30-2009, 10:49 AM hahaha... ok i have a 2001 1500 and its been wreaked i have every thing that i need to make it work, but you anserd my ?. i dont have time to do all of that.... thanks.... it will fit in a 95 and up pretty easy,right? some guy fit corvette V8 into a Civic. like i said before - time, $$, and tools will fit anything into anything. wafrederick 07-01-2009, 06:52 PM I agree it takes time,money and the tools needed.I have seen a Mercedes Benz with a Hemi drivetrain out of a 1968 Dodge under the hood Arrowshooter 07-14-2009, 04:00 PM I am going to say that the motor and trans should bolt right in. You might have to mess with the trans mount an cross member. As for the electrics you are on your own.:wink: vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
