Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Buick > Regal
Old 06-26-2009, 12:11 PM   #1
dwaynlakrz
dwaynlakrz Normal reputation
i need help
i have a 1999 regal gs 3800v6 165000 miles---this morning my car was misfiring real bad so i took it to autozone to get the code anyway ---there misfire a in cylinder 4 i changed spark plug, module and wire same problem--i un pluged my super-charger 6month ago but i notice the pulley is moving without a belt--there is a sensor on the passenger side of the super-charger continus to pump---what is the problem
dwaynlakrz is offline   Reply With Quote
Old 06-26-2009, 02:19 PM   #2
HotZ28
AF Moderator Elite
HotZ28's Avatar
HotZ28 +50
Re: i need help
Did you change the coil? The SC pulley will turn with the engine running, even without a belt, otherwise how would the engine get air?
“Ye shall know the truth and the truth shall set you free."
HotZ28 is offline   Reply With Quote
Old 06-26-2009, 02:54 PM   #3
dwaynlakrz
Re: i need help
i just got the one from my other regal--could the #4 cylinder be bad the car will run and start but with a misfire
Old 06-26-2009, 03:47 PM   #4
HotZ28
AF Moderator Elite
HotZ28's Avatar
HotZ28 +50
Re: i need help
Not likely that a "cylinder would go bad" over night! Was the engine running ok until this misfire started? Have you checked all vacuum lines for leaks or loose hose. Is the injector firing on #4 cylinder?
Old 06-26-2009, 04:47 PM   #5
dwaynlakrz
Re: i need help
car worked fine til this morning---ill check 4 vac leak
thanks
Old 06-26-2009, 05:10 PM   #6
dwaynlakrz
Re: i need help
how can i check the injectors
Old 06-27-2009, 01:25 PM   #7
dwaynlakrz
Re: i need help
could it be one of the sensors my brakes are hard also
Old 06-27-2009, 01:38 PM   #8
richtazz
parts monkey slayer
richtazz's Avatar
richtazz +50
Re: i need help
You need to check for vacuum leaks and do a compression test. Since this car is a GS with the supercharged 3800, do you run 87 octane in it on a regular basis? If you did before you disconnected the supercharger belt, you may have damaged the #4 piston due to knock/detonation as this is the hottest running cylinder on these engine and most prone to detonation damage. If you have a blown piston, this will cause low engine vacuum and a hard brake pedal as well as a misfire.
Why is the supercharger belt off anyway?
Would you drive any better with that cell phone up your ...?!
richtazz is offline   Reply With Quote
Old 06-27-2009, 02:03 PM   #9
dwaynlakrz
Re: i need help
i ran nothing bu 87 octane can the # 4piston be chzanged out
Old 06-27-2009, 02:06 PM   #10
dwaynlakrz
Re: i need help
one of the pulley broke on the highway---and never did replaced it
Old 06-29-2009, 03:51 PM   #11
dwaynlakrz
Re: i need help
what tool and procedure i need to check compression on the vehicle?
Old 06-29-2009, 08:40 PM   #12
HotZ28
AF Moderator Elite
HotZ28's Avatar
HotZ28 +50
Re: i need help
Pull the plug on #4 and check for oil foul. If the piston has damage, you would here a knocking noise. A compression gage would be available at most auto parts stores and is all you need to check compression. Follow the procedure included with the instructions!
Old 06-30-2009, 11:35 AM   #13
Ruley73
Ruley73's Avatar
Ruley73 Normal reputation
Re: i need help
Are you saying you're driving the car without the S/C belt or just mentioning your observation with the S/C belt off and the engine running?
As far as the 87 Octane gas goes, if he is driving the car w/o the S/C he doesn't need the higher octane gas since he isn't using any boost. Otherwise, yes higher octane gas is mandatory. Sadly, I can guarantee that many folks that drive those S/C cars use 87 octane as well. If you don't drive your car too hard you can get away with it, but I still don't recommend it. If it knocks though you are already causing damage to the engine.
FWIW I would also check the #1 plug and wire since they share the same coil. I have seen OBD-II report a misfire on the opposite cylinder before.
I would also try moving the coils around to see if the misfire follows. If it does the coil is bad.
Your brakes may be hard since the booster isn't getting enough vacuum due to the S/C not turning (if you are driving it that way).
My ride: blackberry 2000 Saturn SC2, 5-speed, lowered, bolt-ons
Wife's ride: white 2007 Chevy Equinox LT FWD...stock for now
Ruley73 is offline   Reply With Quote
Old 06-30-2009, 03:49 PM   #14
dwaynlakrz
Re: i need help
i drove the car 8 month without sc belt--and didnt drive hard mostly highway miles used only 87 octane---i replaced module and all coil packs saturday the car will start mis real bad replaced #1 #4 plug---there a round black module like thing-on the right side of the super charger-there a in and out hose connect to sc just keep pumping opposite side of the erg val--also there a small noise sound like it's comming from idler pulley area?1991 regal gs why am i getting code 13---i replaced crank sensor new?
Old 06-30-2009, 05:22 PM   #15
richtazz
parts monkey slayer
richtazz's Avatar
richtazz +50
Re: i need help
code 13- Oxygen sensor voltage stays between 0.35 and 0.55 volts for 30 seconds when the TPS signal was above 0.55 volts. The engine had been running for at least 40 seconds with an engine temperature above 110� F.
This code has nothing to do with a CKPS, so why did you change it?
Bookmarks
Google
Web AF
