11-12 mpg2bbows 06-24-2009, 11:48 PM I just resently picked up a 99 jimmy 4.3 is 11-12 mpg in the city, normal just seemed a little low to me. thanks mike 4x4 blazerguy 06-25-2009, 03:46 AM Yea I'd say way too low. Heck I get 9-11 MPG out of my 1986 Ford F250 4x4 with a 460 in it. Our 97 Blazer 4x4 4.3 gets 20-22 MPG. Our 98 Jeep Grand Cherokee 5.9 Limited gets 14-18 MPG. Are you getting any codes? I would start with checking plugs, wires, & fuel leaks. 2bbows 06-25-2009, 09:39 AM Right after I got it about 1 month ago I put in new plugs, checked the wires, new fuel and air filter, no change in mileage. No codes thanks mike Leeann94astro 06-25-2009, 01:46 PM What temp is it running? 2bbows 06-25-2009, 02:24 PM It is running in the 200-210 range Leeann94astro 06-25-2009, 04:23 PM Okay, then. When you replaced the plugs, how did they look? Were they coffee-colored, black, white, what color? Also, have you checked your cap & rotor? Rick Norwood 06-25-2009, 07:58 PM I just resently picked up a 99 jimmy 4.3 is 11-12 mpg in the city, normal just seemed a little low to me. thanks mike You should be seeing at least 16-18 MPG in the city. Start with the basics. Before you throw a ton of cash at it, you might consider a diagnostic check at a reputable garage, maybe one with an Emissions or Exhaust Analyzer. You could be dumping huge amounts of unburned Gasoline into your exhaust system. I would also check for vacuum leaks, missing or rotted vacuum lines and hoses, PCV Valve, and maybe a little fuel system cleaner. Since the Plugs are done, Spark Plug Wires, Distributor cap and Rotor would be my next thought. After that, Oxygen Sensors. 2bbows 06-25-2009, 09:50 PM The Plugs that came out all looked really good, the plugs that came out were like a platium plug with the small pionted electord the one the local parts gave me for replacements were just standard plugs, I would not think that would make that much differance. I have not checked the cap and rotor yet, I guess that will be the next step, we do not have smog testing around here, but I do have access to a scanner, is there somewhere I can look to see what the readings should be. It idle and runs great and only has 80K. thanks Mike 4x4 blazerguy 06-26-2009, 12:49 AM If you did not go back with the platinum plugs AC Delco are highly recommended by most of the guys I know running Blazers then that could be a lot of your problems. 2bbows 06-26-2009, 09:38 AM Ok, thanks I will change the plugs this weekend and check the cap and rotor. Is there a place on line that I can lookup the readings ranges that should be if I get a chance to hook a scanner up? thanks mike 4x4 blazerguy 06-27-2009, 03:20 AM I can't help you with any reading ranges. The reason I say the plugs is the OEM plug for your Blazer was a Platinum AC DELCO Plug. 2bbows 07-01-2009, 09:35 AM well got the plugs, cap and rotor changed, cap and rotor needed it so donnt fell like a waste of time or money, will see if things improve. thanks for the help so far. mike vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
