finally found someone to change my isolator bolts and gaskets. runs a little better but still pops when excelerating and once levels off is runs pretty good... better than when i had the 171*174 codes. engine light came on four days after the work was done. now showing 401. changed egr valve when first codes came up. run worst when air conditioner is on... 101 here in louisiana need my ac.... any ideas???
yep, it's likely the dpfe. Seems funny but lots of people do the 171/174 and then the 401 code shows up. The dpfe is a really quick and easy change. Do a search and you'll get lots of hits.
Piper
Agreed, when I did my isolator bolt TSB last fall, I just went ahead and changed the DPFE at the same time just to avoid the problem. The key was if you had an original Ford DPFE, it was aluminum metal in color. This is the one you should replace. The later Ford model and after market ones (got mine at AutoZone ~ $35) are black plastic.
__________________ 2000 Windstar SE 3.8L 54k miles (wifes) 2006 Hyundai Sonata LX 3.3L 43k miles (mine)
I would leave it be as long as it is working.
While tracking down a slight miss......I replaced my original one with a metal Standard Motor Products unit...... Original was still good.....and the replacement is still good.
Slight miss was caused by dirty fuel injectors that many fuel system cleaners would not clean (I have since found that Berryman's B-12 Chemtool seems to work on these particular deposits the form on the inside of the end cap).
Well, tested dpfe it was working properly... My boyfriend had a digital meter....according to manuel it is working properly... Any other suggestions.... Added techron also to my tank on saturday.
You could check the vaccum lines to the EGR valve.....
Otherwise, if the EGR ports are clean, the most likely suspect is the DPFE....maybe it is intermittent.
I am hoping that the EGR ports were verified as clear when the isolator bolts were done.....as they were right there.
EGR valve rarely fails on the Windstar.
