Re: accord lagging
I'd change the fuel and air filters if it's been a while just to eliminate that aspect.
But only happening after warm-up hints at a closed loop (full feedback fuel management) problem...
Several items are disabled when the engine is cold, EGR, torque convertor lockup, o2 sensor is ignored, etc. Any one of those or more could cause this kind of problems.
When it starts acting up does it buck violently, or just sag and lose power, or rhythmic misfire, or something else?
Many things can be happening here...but a shot in the dark, it sounds like it's losing power which accounts for the prolonged wait for upshift (it's trying to stay in powerband by holding the lower gear until you hammer on it).
Anything from low fuel pressure to retarded ignition/valve timing to a partially clogged cat convertor can do this.
How's the engine temp? Normal? How many miles on this car? When was the timing belt replaced last? Did this come on suddenly or has it been working up to it for a while?
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
