Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Buick > Regal
Old 06-24-2009, 03:00 PM   #1
3800Regal92
3800Regal92 Normal reputation
Mono spring????
searching high and low for a mono leaf spring! goes in the rear eand of my 3800 regal, i can find the bushings, the insallation/removal tool but not the actual spring, i really don't want to go dealer part only on this, can anyone help?
3800Regal92 is offline   Reply With Quote
Old 06-25-2009, 05:27 PM   #2
richtazz
parts monkey slayer
richtazz's Avatar
richtazz +50
Re: Mono spring????
Regretfully, they are a dealer only part. I don't know of an aftermarket company that makes a reproduction version. Have you checked e-bay and such?
Would you drive any better with that cell phone up your ...?!
richtazz is offline   Reply With Quote
Old 06-25-2009, 09:42 PM   #3
toddman67
toddman67 Normal reputation
Re: Mono spring????
Try www.wilbertsgmparts.com I looked one up and they show having it. It's not in your area, but they will ship. Give them a call.
toddman67 is offline   Reply With Quote
Old 06-26-2009, 09:41 PM   #4
3800Regal92
Re: Mono spring????
thanks for the link didn't want to go dealer, a new one is more than my blue book
Old 06-26-2009, 10:01 PM   #5
toddman67
Re: Mono spring????
No problem, Give these guys a call, they are a class act salvage yard that specialize in Buick and GM parts. If they don't have it they can usually find what you need for you.
Old 06-26-2009, 10:16 PM   #6
3800Regal92
Re: Mono spring????
sweet, not to change subject but i changed my fuel pump, still stalls, goiung for crank sensor now, what do you think
Old 06-26-2009, 10:33 PM   #7
toddman67
Re: Mono spring????
First of I would check for flash codes. Check www.troublcodes.net for information. Also many times these stalling issues can be solved by removing the throttle body, removing the sensors and cleaning it good with throttle body cleaner. Make sure the passages are clear. Vacuum lines are also a major cause of stalling. Check and clean EGR valve if applicable and the IAC valve seat and plunger.
Old 06-26-2009, 10:57 PM   #8
3800Regal92
Re: Mono spring????
new iac, icm, o2, fuel filter, fuel pump, plugs-wires, thermostat, coolant change, air filter, cleaned MAF sensor, most vacum tubes/hoses, new computer did nothing so i returned it, last code i got was 17 (some sort of rpm crank signal count problem)?? sounds like crank sensor to me.
Bookmarks
Google
Web AF
