05 silv both fan fuses blown
Google
Web AF
jmull256
06-24-2009, 02:04 PM
it was a normal hot fl day sitting in drive through i noticed a very strong electrical burning smell and neither fan was on even with ac running and temp way above norm it cooled off after very short time driving and when home i discovered both fuses blown i replaced and seems ok for now but i cant figure why both fuses would blow together or at all for that matter the truck has just under 55000 miles and has always worked fine
j cAT
06-24-2009, 05:21 PM
what are you talking about radiator fans..?
jmull256
06-24-2009, 07:00 PM
yes radiator/cooling fans
j cAT
06-24-2009, 07:52 PM
from the fuse box to the fan mounting area the wires will follow a common path,,,inspect the wires for damage...was this vehicle accident damaged/body repair etc..
jmull256
06-24-2009, 08:02 PM
ohm tested wiring between fuse block and fans checked out ok fans run fine when connected to bat+ individually vehicle has never been wrecked as i have owned it since new everything i can think to check is working normal i just think blowing 2 40 amp maxi fuses at same time along with the smell is odd and i cant figure it out i have also pulled the wires out of the wrap and inspected visually with no signs of damage to wires or connectors
j cAT
06-24-2009, 08:17 PM
I would inspect under the fuse box...
disconnect connectors for damage/corrosion
Google
Web AF
