Originally Posted by gregz28
I have a 2008 Silverado that I have installed 22" Wheels and tires (22x9.5 with 305/40-22 tires). Prior to the install I had none of the problems that I am going to talk about. After installing the wheels & Tires I had a couple different vibrations going on. The first I figured was a wheel balnace problem and after having the wheels and tires Re Balanced the first has gone away. The second vibration occured whenever I step on the brakes. I get a pretty severe vibration which seems to be coming from the rear of the truck. This seems not to happen everytime the brakes are applied. I am so happy with the way the truck looks with the 22"s but I can not live with this vibration (yeah I know DON'T use the brakes). Could this be an issues with the ABS?? HELP Please!!!!!
pulsations and wheel slip may be your problem...reduce the tire pressures in the rear tires by 15% and see if it improves...
the low profile tires are stiff....like to bounce..
