Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Caravan/Voyager
Old 06-24-2009, 09:57 AM   #1
MONTEHEEREN
MONTEHEEREN's Avatar
MONTEHEEREN
Question 2006 Dodge Grand Caravan Oil
Can I run 5W/30 oil in my 2006 Dodge Grand Caravan? The engine is a 3.8 with 52K. The manual says to use 5W/20. 5W/20 just seems way to thin. Its like pouring water in the engine. I was talked into trying Northland 5W/20 synthetic oil for my van. It looks green coming out of the bottle. After changing oil, started the van up and I could hear slight rod knock.
Not - A - Good! So, I went back to 5W/20 Havoline which I had been using.
I've always run 5W/30 in my Dodge vans. This is the first van that it says to use 5W/20.
MONTEHEEREN is offline   Reply With Quote
Old 06-24-2009, 11:39 AM   #2
Airjer_
Airjer_'s Avatar
Airjer_ Normal reputation
Re: 2006 Dodge Grand Caravan Oil
At 200 degrees you would not be able to distinguish the difference in thickness between the 2 different weight oils. Run what the manufacturer recommends.
Airjer_ is offline   Reply With Quote
Old 06-24-2009, 07:16 PM   #3
Bear
Bear
The viscosity index (10W20) is moe and EPA uissue (better fuel economy) than anything else, CASTROL is currently marketing a 0W30. 10W20 will not hurt your engine.
Bear is offline   Reply With Quote
Old 06-24-2009, 09:11 PM   #4
joe92k1500
joe92k1500's Avatar
joe92k1500 Normal reputation
Manufacturers switched to 5W-20 to improve their CAFE numbers. Some engines are designed to use this motor oil, but our engine designs haven't really changed since they said to use 5W-30 in them. The same thing happened to my old 2001 Taurus. The year before, they said 5W-30, and in 2001 said 5W-20. My friend was a master Ford mechanic and he told me this. So, I use 5W-30 in my van.
joe92k1500 is offline   Reply With Quote
Old 06-27-2009, 08:38 AM   #5
RahX
RahX Normal reputation
Just use what is recommended, you will not see any difference between them. This isn't the 60s when you sculpted main bearings out of babbit.
RahX is offline   Reply With Quote
Bookmarks
Google
Web AF
