Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Isuzu > Rodeo/Passport
Old 06-23-2009, 06:36 PM   #1
wb4lbg
wb4lbg Normal reputation
How much Seafoam?
My '99 LSE burns a quart of oil about every 600-700 miles - more when driving at 70-75 mph. I switched to the Rotella oil the last couple of oil changes and haven't seen any real improvement.
I'm considering doing the Seafoam flush I've read about but I wanted to to get some advice from the experts.
It doesn't seem that anything that goes into the oil would really do much to clean out the drain holes that are apparently plugged up -- especially if it's only in there for a few minutes. How many oil changes will I need to add Seafoam before I start to see some results?
Is there anything better to use than Seafoam?
Will the Seafoam do any damage to the valve stem seals or any other internal engine parts?
Thanks!
JWS
'99 Rodeo LSE 4WD
'00 Escort ZX2
'00 Olds Silhouette
'95 Mazda Protege'
wb4lbg is offline   Reply With Quote
Old 06-24-2009, 10:45 AM   #2
klvaleri
klvaleri Normal reputation
Re: How much Seafoam?
If I were you I would try this product call Auto-RX first before seaform and replace PCV and clean EGR tube or Line and see how much improvement will you have. This is my 2 cent.
1999 RODEO LSE 4WD V6 3.2L
2001 Accord Sedan EX V6
klvaleri is offline   Reply With Quote
Old 06-25-2009, 01:04 AM   #3
anthonyn
anthonyn Normal reputation
Every few months I feed about 1/4 bottle of seafoam through the pcv valve with the engine revving above idle. It really helps to clean out the combustion chamber. Lots of white smoke through the tail pipe, but it always feels peppier afterwards. I don't recall if it helps with oil consumption because it isn't a major problem for my rodeo. You could also use the brake booster line to suck up the seafoam. Not sure if one is better than the other.
1995.5 Rodeo, AT, 3.2 L, 2WD, 124k miles
Manik Grill guard & Nerf bars, Passport fender flares, Dynomax Turbo muffler, Modified Air intake
anthonyn is offline   Reply With Quote
Bookmarks
Google
Web AF
