Originally Posted by swoop
I have a question about changing out my sons compressor. When I open up the system to change out the compressor, I want to change out the accumulator as well becuase it is where the oil is stored right? Then change the orifice tube. Before I recahrge the system I will take it and have the ac system vacumed and then recharged. Does this sound like the right sequence? And is there a way that I could pull all the moisture and air out of the ac myself before I recharge??
Swoop
The only you can pump it out and do it yourself is if you have a vacume pump and the ac recharge gauge kit.
http://www.ackits.com/c/DIY/Do-It-Yo...ance+Kits.html
http://www.ackits.com/merchant.mvc?S...erantGaugeSets
http://www.ackits.com/merchant.mvc?S...egory_Code=DIY
The accumulator only holds about 2 oz oil.
The ac system oil is spread out over the complete system.
To get the righ amout of oi back in the system the system should be flushed out and the correct amount and kind of oil added.
Rule of the thumb is 2 0z of oil for every part of system.
2 condenser 2 dryer 2 compresser and 2 evaporator.
When you pull compresser and accumulator measure what come out of them.
If 2 oz in each one the the other 2 condenser/evaporator should have about 2 oz in them .
Then I make sure new compresser is dry or drain if not and add 2 oz oil to compresser and 2 oz to accumulator/receiver dryer.
Remember when changing the comprsser and dryer/ accumulator out the dryer comes dry no oil and compressers come dry and sometimes as much as 8-10 oz oil in them.
Letr us know how it goes.
Good Luck
