Hard to Start, 1st 2nd or 3rd tryKolorado Ken 04-01-2003, 09:56 PM 735il runs well, idle is just a little rough sometimes. New plugs, compression is OK, etc... however it sometimes starts on the 1st try, seldom the second crank, and always the third. Never need a four try. Anybody have a clue as to why it does not start first try? cos3 04-11-2003, 05:45 AM fuel filter maybe kaoru-tochiro 04-11-2003, 08:41 AM are you doing regular maintenance, you know:spark plugs, filters, etc...? Kolorado Ken 04-12-2003, 09:36 AM maintenance - yes, the fuel filter, plugs, etc...have all been maintained kaoru-tochiro 04-12-2003, 03:17 PM Does this happen more in warm weather? it might be a sensor that activates the cold start valve, or the valve itself. Kolorado Ken 04-14-2003, 04:48 PM It happens both in warm and cold weather. I've noticed that it happens more often when the engine is warm, however it is common that it happens regardless of weather or engine conditions. jay76silver 04-17-2003, 08:10 PM try fuel system cleaner, if no - check fuel preasure. Kolorado Ken 04-19-2003, 01:05 PM thanks, I think you are on the right path - after further investigation I now the fuel pump is weak and needs replacement. I'll do that within the next week or two. I've also started using some injector cleaners in the gas to see if this helps. Automotive Network, Inc., Copyright ©2012
