Intervals For Rear Brake Replacement?Off_Timing 06-22-2009, 10:16 AM Hi. Just wondering what interval (time or mileage) do you guys replace the rear brake shoes on your Windstar? Thanks. Airjer_ 06-22-2009, 11:04 AM When there worn out! If there riveted before they get to the rivets. If there bonded than somewhere between a 1/16 and an 1/8 inch is when I start recommending them. Ed_Strong 06-22-2009, 11:58 AM As Airjer said... there's no secret formula or schedule! It all depends on your driving style and conditions. City driving usually means a short brake components life so you'll have to change them sooner. Visual inspections regularly is the best preventive maintenance when it comes to brakes. 12Ounce 06-22-2009, 01:41 PM Visual inspections regularly is the best preventive maintenance when it comes to brakes. I agree. I remove the rear drums for a look-see-cleaning-lubricating-adjusting everytime the front pads are replaced. wiswind 06-22-2009, 07:53 PM Rear drum brakes tend to last a lot longer than the front disk brakes.....most of the work is done by the front brakes. When doing the rear brakes, I would recommend buying a drum brake hardware kit. This will make the job easier and will be more reliable......only costs a couple of dollars. Here is a link to the first in a series of pictures of a rear brake job on my '96. http://rides.webshots.com/photo/1402640004011220610MUaUIA Off_Timing 06-23-2009, 02:40 PM Brakes have always been the one thing that gets the least attn....even though it should be near the top cause it's a safety system. It's sched'ed to go to the mech next week for a brake job. Forgot about the drum brake kit. I'll bring those along with a good set of drum shoes. Thanks for the input guys. Automotive Network, Inc., Copyright ©2012
