Re: 90 caravan no power to coil
If your van is designed like later model vans it sounds like you lost the camshaft or crankshaft sensor signal. If the engine computer doesn't see this, it will remove the ground from the Automatic Shutdown (ASD) relay. This action opens the ASD relay contacts, cutting power to the ignition coil, fuel injectors and fuel pump and O2 sensors. Ckeck for power at the sensors and injectors. If there's no power then the sensors or their wire harness and connections are suspect.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
**DIYer and multiple automotive forums junkie for years. Air Force career in aviation electronics.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan / 94 Camry
