Originally Posted by icefishingnut77
thanks icat I took them back off and ground down the roughness. its like they have no quality control in china. I had another question. there is a wear sensor on all the pads i usually only see one on each wheel. does it matter how the sensors are installed? both on top, one on top one on bottom? I wouldnt think it would matter when it gets that bad that you get to that point you need new pads anyway.
thanks for the advice
gs
I can't remember exactly/also some pads are not with these wear indicators...
as long as the pads fit properly and move smoothly in the holder/caliper you will be fine...
I also coat the pad backing metal with a paste anti seize compound. this will prevent pad noise. make sure that the caliper piston seal is properly seated so that it will not get damaged...
