Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 06-20-2009, 01:58 PM   #1
flyawayde
flyawayde Normal reputation
Unhappy 2000 Cavalier just died. Won't stay running
I was driving, everything was fine. Pulled up to a light and it died before I stopped. Didn't wanna start. Got it going, but barely running. Shaking and sputtering, had to keep restarting it to get it into a parking lot. One shop said fuel pump, one said fuel filter, one said spark plugs and wires, or coil pak. It doesnt have spark on 1 cylinder. Stinks when trying to keep it running. Does anyone know what the problem is so I don't have to spend all this money trying all these different fixes? Thanks.
flyawayde is offline   Reply With Quote
Old 06-21-2009, 12:52 AM   #2
J-Ri
J-Ri's Avatar
J-Ri Normal reputation
Re: 2000 Cavalier just died. Won't stay running
You don't have to "try" any fix. Check the fuel pressure. Cycle the key a few times until the pressure stops rising. With the engine off, this will also check for a plugged filter since there's no flow. If it's not low, check spark. Two of these shops were obviously wrong. A plugged fuel filter will really only limit your top speed which will gradually drop. I have never seen a plugged filter cause a problem with the large canister filters like on your car. The old 3/4"x2" element filters in carbs would plug and cause problems, but there's just so much surface area on your filter I really don't see it being plugged unless foreign material found its way into your tank. Only losing spark on one cylinder probably wouldn't make it die. It would run rough, but would keep running. I realize I eliminted all but one possibility, but do the checks anyway. That was all just guess-work, educated guesses, but guesses nonetheless. There's also a possibility all 3 shops were wrong.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
When you buy something... a bottle of pop for example, who gets the profit from it and what do they do with it? Maybe your money's going to groups that want to hurt you. I think everyone should do a search for things they purchase regularly "____ supports". Might just find a company you won't buy stuff from anymore.
J-Ri is offline   Reply With Quote
Bookmarks
Google
Web AF
