96 Windstar-3.8 engringo7 06-19-2009, 12:48 PM I do not have Vacum supply to the Air-Conditoner-Heater Select Switch- There are 6 Vacum supply Hoses-a Yellow-a Blue-Orange-Red-Green-Black ,These Go to Doors. and the Elec;Plug to same Switch has Pink-(Green/white) Purple-Pink 4 total these are at top of same switch So none of the doors will open; I tried following these Vacum Lines iside the Eng area,But can not locate where the Supply line connects; any advice:) is appreciated; Davescort97 06-19-2009, 03:50 PM Check all the vacuum lines at the engine. There are some ports off of the intake plenum that go to a vacuum block. Some times the ends of the hoses get dry and crack out. You can check the good hoses by squeezing the hoses with a pair of needle nose pliers. If you hear a difference in the sound of how the engine is running, then this is a line that is leaking or is disconnected. Try to back track the offending vacuum line to the vacuum supply hoses at the blend door of your heater/AC controls. Listen for a characteristic whistling sound a missing vacuum line will make. The only other thing I can think of is that the vacuum motor at the blend door(s) is bad. Did everything revert to the defroster when it started going bad? It is a safety default mode. ringo7 06-19-2009, 05:00 PM Check all the vacuum lines at the engine. There are some ports off of the intake plenum that go to a vacuum block. Some times the ends of the hoses get dry and crack out. You can check the good hoses by squeezing the hoses with a pair of needle nose pliers. If you hear a difference in the sound of how the engine is running, then this is a line that is leaking or is disconnected. Try to back track the offending vacuum line to the vacuum supply hoses at the blend door of your heater/AC controls. Listen for a characteristic whistling sound a missing vacuum line will make. The only other thing I can think of is that the vacuum motor at the blend door(s) is bad. Did everything revert to the defroster when it started going bad? It is a safety default mode. Yes 97 my wife complained of Air coming out at Defrost; Long story Short there was no Clutch Comp; I bought a ccrm at Salvage yd. 30 dollars the Fan relays and comp Relay are in a sealed unit;also I replaced Air Dryer and Orfice,Put vacum on system 5 hrs; Jumped the Clutch cut off Switch and serviced System ,This 96 -3.8 Windstar has two Air cond Evaporators,Everything is working fine,With one Eception,There is no vacum at each door,I Tied the Door open to allow cooling come thru the dash vents;nice and cool, and the back unit is good;;;; Since I did not have Vacum at any door,I disconnected the 4 Vacum lines at the blend control, No vacum,there, is also an elec. plug also at this Selector;I was going to check the Vacum Resevoir under hood passenger side;Thanks for the Tip. ringo7 06-20-2009, 11:37 AM Yes 97 my wife complained of Air coming out at Defrost; Long story Short there was no Clutch Comp; I bought a ccrm at Salvage yd. 30 dollars the Fan relays and comp Relay are in a sealed unit;also I replaced Air Dryer and Orfice,Put vacum on system 5 hrs; Jumped the Clutch cut off Switch and serviced System ,This 96 -3.8 Windstar has two Air cond Evaporators,Everything is working fine,With one Eception,There is no vacum at each door,I Tied the Door open to allow cooling come thru the dash vents;nice and cool, and the back unit is good;;;; Since I did not have Vacum at any door,I disconnected the 4 Vacum lines at the blend control, No vacum,there, is also an elec. plug also at this Selector;I was going to check the Vacum Resevoir under hood passenger side;Thanks for the Tip.I pulled the dual vacum lines from Vacum Reservoir,There is Vacum from Red One but the Black Line I assume goes to Selecter on the dash;I do not know if Vacum is coming out of Reservor? Automotive Network, Inc., Copyright ©2012
