73 cuda hemi project need help
brians cuda
06-19-2009, 04:28 AM
Hi can anyone help me. I have bought a 73 barracuda with a small block and want to go hemi. Can this be done, do I need a new K member or is there a kit to convert to big block? I am in Australia so will need to find parts to bring to Oz.
MagicRat
06-19-2009, 09:27 AM
Welcome to the forums!
I noticed you also posted this question in the Plymouth non -specific forum.
Usually we discourage members from starting duplicate threads on the same subject.
Many of our members, including maxwedge and MrPbody, really know their stuff on old performance cars..... I am sure they can provide some advice.
I believe the 6 cyl and V8 K-members were different. I will tentatively suggest your existing K-member will have to do, I'm pretty sure original Hemi K-members are simply not available.
There may be other mods for installation to ensure clearance. I believe the Hemi and 383 and 440 engines used stronger front springs than the smaller, LA block-equipped cars. Also, there were other chassis changes for the larger engines, too. I believe the right-side rear leaf spring pack had one more leaf than the left side , to control wheelspin. Hopefully others will chime in with ideas.
maxwedge
06-19-2009, 01:38 PM
The trans will not work, you need a 727B also there are companies that make motor mount adapters that will fit the hemi to your existing k-frame, this is a big bucks undertaking!!!!
brians cuda
06-19-2009, 04:16 PM
Thanks Maxwedge, can you suggest anyone who can supply the k frame mod kit? if there is one? As far as the trans I was aware I would need the 727 but what is the 727B, I assume different bolt pattern to match the Hemi, Maybe could make an adapter plate? I have looked at Magnum force website and see they make a frame with RHD rack and pinion to suit the Hemi. Still to find a suitable transmission. I also understand there are big $$ involved but bit by bit I will make it happen, "Famous last words" thanks Brian
brians cuda
06-19-2009, 04:18 PM
Thanks for the tip Magicrat, I was not sure if I posted in the right place, will keep in mind next time, Brian
maxwedge
06-19-2009, 08:23 PM
Brian any of the Mopar performance mags out there have all the parts/advertisers you need to get this done, also headers or exhaust are expensive. The small block trans is no good for the Hemi, the 727B fits all the 426 Hemi's and raised blocks 426/440 wedges. I ran my pictured Max Wedge race car for 2 NHRA seasons with an aluminum ft end and crossram Hemi SS engine set up, I used the Hemi K member then as this was required.
brians cuda
06-21-2009, 04:42 AM
Thanks Maxwedge, It's a big help. I have only just today found some one willing to sell me a 727 off the back of a 440, pretty close to home too. I do need to do a bit more homework before I start the project, thanks again. Brian
