Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Silverado
Old 06-18-2009, 09:54 PM   #1
yeloblammo
yeloblammo Normal reputation
00 Silverado won't start
00 Silverado, 177k miles
I've never had a problem with this thing, ever.
I drove to the gas station on my way home from work. Filled up 1/2 tank, went to leave and all it did was crank. It will just crank and crank but wont turn over.
I checked all the fuses and swapped relays around. nothing
I have all my electricals.
oil and coolant is full.
i have to go back to the gas station and get it running before they tow it.
any suggestions?
yeloblammo is offline   Reply With Quote
Old 06-19-2009, 10:46 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: 00 Silverado won't start
You need to check for lose of spark or fuel pressure.
What engine do you have?
Any security lights or check engine lights or codes?
MT
MT-2500 is offline   Reply With Quote
Old 06-19-2009, 12:35 PM   #3
brcidd
brcidd's Avatar
brcidd Normal reputation
177k miles and never had a fuel pump? You have truly been blessed--
Check your fuel pressure- or better yet blow some carb cleaner in the air intake- see if it tries to start in that...If so - you can pretty much rest assured your FP is history--
Oh- you can try the Whapppp on the tank if the fuel pump is proven inop- it may just jarr it enough to let it run, so you won't need the tow...done that about half the time.
Automotive A/C Engineer with:
'95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone- blown head gasket
'92 Chevy Lumina Van 3.8L 264k miles
'86 GMC S-15 - 2.8L 154k miles
'86 Buick Park Ave 3.8L 199k miles- my daily driver
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles- my high school car!!
All but the Camaro and Firebird are white....
brcidd is offline   Reply With Quote
Old 06-19-2009, 12:55 PM   #4
yeloblammo
it has the 4.8 V8
The check engine light is on, but the car isn't running. that light is always on when i turn the key forward. It had never came on before i got gas.
I had already wiggled/checked all the wires for the plugs and injectors while i was in the parking lot waiting for a ride. nothing obvious.
This happened out of the blue.
i ordered a FPR so i'll have that this afternoon.
Things i'll try next.
1. spray gas in the TB
2. whap on the tank
3. change out the fpr that i ordered.
hopefully that will do it. i don't want to be changing the FP
my brother just had the exact problem with his a month back but he hasn't resolved it yet.
Old 06-19-2009, 02:23 PM   #5
MT-2500
AF - Advisor
MT-2500's Avatar
Proper testing before throwing parts at it.
Got good hot blue spark to all plugs?
Got fuel pressure?
What is the fuel pressure readings.
MT
Old 06-19-2009, 04:06 PM   #6
j cAT
j cAT Normal reputation
why did you bother to spend time posting your questions ???
just start replacing parts...soon you'll get tired of spending cash for no positive results...
j cAT is offline   Reply With Quote
Old 06-19-2009, 06:57 PM   #7
sierra99
sierra99 Normal reputation
Did your fuel pump make a whinning noise when running before??
Can you hear it running now??
When my fuel pump went out at 147k miles I could put the key in the on position and then let the pressure build up enough to get me home to change it out.
Try that and see if that helps.
sierra99 is offline   Reply With Quote
Old 06-20-2009, 01:20 AM   #8
jyount
jyount Normal reputation
Is that a stab at the carb cleaner trick? Or him replacing the fpr for no reason. Far as I am concerned, the carb cleaner trick is by far the fastest and most proven trick I know of to check for fuel. If it hits he has spark...
10 credit hours away from John Deere master certified tech.
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while. So schooling there too....
Also couple years exp in GM and some GM training
01 Malibu, 4dr
1990 Acura Integra GS 5spd FOR SALE
98 TJ 4in lift 33's 4.10s 2.5 5 spd FOR SALE
05 K truck. SOLD
Wife's truck. 04 T (trailblazer) ext. 5.3 4l65
got the piston slap.....
jyount is offline   Reply With Quote
Old 06-20-2009, 09:13 AM   #9
j cAT
the reason I said what I said is ,,,he is not following the recommended process of elimination by troubleshooting this correctly...
he is just buying parts ...
proper testing is the only way to properly repair any type of elecronic/electrical equiptment...
Old 06-20-2009, 10:22 PM   #10
kahjdh
kahjdh's Avatar
kahjdh Normal reputation
My money is on fuel pump,
He was low on fuel which let the pump heat-up, Fresh half tank of cold gas squeltched (sp?) the pump. Very common to die at the pump.
I find that the whap on the tank is relativley successful, Carb clean works better if you have it. Remember he was stuck at a gas station so that rules out scanning for codes or a fuel press test.
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV 3.4L
kahjdh is offline   Reply With Quote
Old 06-21-2009, 12:31 PM   #11
yeloblammo
so far..
sprayed some carb cleaner in the TB and it tried to run. more so than just trying to start it up without it, where it would just crank
whapped the tank w/ a hammer. no luck.
pulled the vacuum hose on the fpr, it was dry, no gas.
i have no way to check fuel pressure right now since i don't have a guage.
i can't say i ever heard the fuel pump whinning prior to this
Old 06-25-2009, 10:28 PM   #12
yeloblammo
I am having one hell of a time getting the lock ring of off the fuel pump.
It is rusted like crazy and almost hard to tell what is actually a structural part of the ring. I tried to rotate it with a punch and hammer and it flakes apart.
It looks like it has 3 hooks located at 4, 8, and 12 o'clock that hold the ring down. I tried rotating ccw like stated already and it won't budge.
Am I missing something or it is just frozen on? I don't like using too much force when I'm unsure of how it comes apart.
Old 06-26-2009, 12:20 AM   #13
j cAT
so what was the fuel pressure????
got some wd-40 ???
how did the fuel pump electrical grounds look??
Old 06-26-2009, 07:58 AM   #14
yeloblammo
I soaked the area in wd40. I was suspicious of how the ring came off because of the amount of force i used on it already and it didn't move. I assume it rotates ccw to remove.
electricals look fine.
I know you're going to scold me for not checking FP but i didn't becuase i found it unlikely that my fp would drop so abruptly when i got gas and the truck died. Considering it never showed any signs of failure prior.
Old 06-26-2009, 09:45 PM   #15
hinton08
hinton08 Normal reputation
You need to check for adequate fuel pressure. It could still be a clogged fuel filter. I work at a dealership. Never rule out the fuel filter. I'm not saying the fuel pump isn't the problem but you need to check the fuel pressure. If you have fuel pressure, but its low, it could be the filter. Did you ever check for spark? If so, what was the result? A no-crank condition is pretty broad so there is endless possibilities.
hinton08 is offline   Reply With Quote
Bookmarks
Google
Web AF
