1992 Z24 3.1 Can't get the timing set back right....(MY FAULT)
I have a 92 Cavalier Z24, 3.1. I just bought it off a guy that was convinced that the timing chain had jumped a tooth. It was wanting to start but was backfiring through the intake and exhaust. And when I got the timing chain cover off, the chain had more than normal play in it.
Well, anyway, when I bought the car off him 2 weeks ago, it came with a new timing chain, sprockets, gaskets, oil pan gasket, water pump. So I decided to go ahead and replace the timing chain as well as everything else.
But I screwed up big time....I rotated the motor backwards, (counter clockwise) and now the pistons are running into the valves before it reaches top dead center. And no matter how much I rotate the cam shaft I cannot get the timing set back right to where the pistons aren't running into the valves.
It's really started to frustrate me, this isn't my first timing chain/belt job I have done before, but my first ever on a Chevy 3.1 motor. I know its my fault I screwed up, but I'm just wondering.....
How do I fix it? I can only get the timing marks to line up, like both pointing at 6 o'clock but if I try to get them both at 12 o'clock no matter which way I rotate the motor, it will only go to 1 o'clock or 11 o'clock, since my frustration has about over came me I've tried to turn it both ways.
I know if I do not get it completely 100% right, I'll bend some valves and then have a bigger problem. (In which then I would drop 200 at a junk yard and replace the motor....lol)
I cannot get the motor to fully rotate because its hitting the valves, I've tried everything I can think of myself to fix it and it's just left me frustrated.
Anyone know how I can fix this? Please help.
Thanks
