Re: Not sure what I have? Need confirmation.
Either fluid will work fine in the transfer case.
I'm pretty sure ATF+4 is correct for the transmission. If you do not have an owners manual to check, give the dealer a call to be sure.
Go for gaskets in the diffs. Just make sure the gasket surfaces are completely clean and grease-free before installation.
Many gear lubes have the FM included, but work fine for open diffs. If in doubt, just use a lube specified for limited - slip applications. It will not harm open diffs, it's just a couple of bucks more.
FWIW the front diff is open. The rear might be LS. You can find out for sure by lifting both rear tires in the air with the parking brake released.
Turn one tire. If it turns easily and the other tire turns in the opposite direction, it's open. If it's stiff to turn, pop the trans in neutral. If both rear tires turn in the same direction and the driveshaft rotates, it's LS.
There should be a gasket where both halves of the case meet. So long as it is not leaking and the bolts are reasonably tight, don't worry about the hanging piece.
"We' re all here because we're not quite all there."
I still say a church steeple with a lightning rod on top shows a lack of confidence
