Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 06-16-2009, 04:34 PM   #1
wierdo124
wierdo124 Normal reputation
Blazer Transmission (?) Problem
Hey all, nice site you got here
I bought my first vehicle recently when i turned sixteen. It's a 1996 Blazer LT with a 4.3L V6 and a 4x4 automatic. The engine starts up and runs very well, but when i bought it, they told me something was wrong with the tranny. So we towed it home, and got tabs, etc. Today i took it out on the road for the first time, since it does move. When i took it out, the first thing i noticed was that it will not shift out of first gear. Shifting into D/2/1 does not do anything, it won't hit second gear. Reverse does work. Once i realized this (~1/2 mile down the road) i turned around and headed back home. Most of the way home, i was going up an incline at around 20MPH (~3k RPMs in first gear) and the whole tranny just slipped out and disengaged. It was like it went into neutral. I put her in park, waited for maybe 20 seconds, back into drive, and it took off again, still not leaving first gear. I got into my driveway, and was going to pull into the garage to take a better look, when it does it again, except this time it has a little pull, but not enough to make it up the driveway. At this point, i just park it at the bottom of the driveway and get out to notice there's smoke coming out from under the Blazer. Needless to say, i put her in neutral and we pull it up into the garage with my dad's 2500HD (6.0L V8 oughtta do it ). Once we get it in the garage, we check the tranny fluid. It's a little over full actually, so there's plenty, but it smells burnt.
Am i correct in thinking i'm going to need a whole new tranny? I saw in another thread that it could be the valve body. Can you change that without replacing the entire tranny? Is this even a possible cause?
Help will be much appreciated! (rep for helpful answers)
wierdo124 is offline   Reply With Quote
Old 06-16-2009, 04:57 PM   #2
Leeann94astro
Leeann94astro Normal reputation
Re: Blazer Transmission (?) Problem
If the fluid smells burnt, a new valve body isn't going to help you. The fluid burns due to slippage in the clutches.
Either your existing tranny needs to be rebuilt or you need to find a replacement. If I recall correctly, only a '96 (possibly a '95, but I'm not sure) will both bolt up and talk properly to your computer.
1993 Olds Bravada 4.3L CPI
1993 Chevy Astro EXT AWD 4.3L CPI (not a '94...oops)
Leeann94astro is offline   Reply With Quote
Old 06-17-2009, 09:58 AM   #3
wierdo124
Anyone else??
Old 06-17-2009, 02:00 PM   #4
b1lk1
b1lk1 Normal reputation
Time for a rebuild. There is definitely internal damage. Replacing the valve body, if needed, should be part of the overhaul.
1999 GMC Jimmy SLS (these trucks sure suck the life out of your wallet, LOL!)
Cold Air intake (eBay special with homemade heat sheild)/Throttle plate modded
2" Suspension lift (rear springs/front torsion crank)/1 1/4" read wheel spacers
b1lk1 is offline   Reply With Quote
Old 06-17-2009, 07:38 PM   #5
metallica21156
metallica21156's Avatar
metallica21156 Normal reputation
95 wont match up.
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series split rear, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers. Mag 500's with black center caps, C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
metallica21156 is offline   Reply With Quote
Old 06-17-2009, 11:16 PM   #6
wierdo124
Originally Posted by metallica21156 View Post
95 wont match up.
Which years will?
Old 06-18-2009, 07:23 AM   #7
b1lk1
Originally Posted by wierdo124 View Post
Which years will?
Call a local junkyard, they will have all the exchange info.
Bookmarks
Google
Web AF
