2002 Dodge Caravan stays in Limp in mode
I have a 02 Caravan it stays in limp in mode all of the time. Reguardless of what do you unhook the battery or what ever. I am looking for some input of what could be wrong with it.
I have put 3 TCM's in it new used ones and one reman from Chrysler.
It has a P0755 in it which is 2/4 Solenoid Circuit.
No BATT voltage from terminal 15 @TCM to the transmission control circuit to the TCM relay. That is the circuit that engergizies the relay.
All wires are ok, I have checked all power and grounds to TCM are fine.
I still have no voltage from terminal 15 after the Chrysler TCM, and I am unable to run the quick learn procedure or pinion factor test.
I have used two different scan tools a Modis with the 8.4 update and a brand new solus .
There are no codes present at this time, but it still will not perform the quick learn procedure. If I go drive it the PO755 will return.
Any input is welcome.
Thank you,
Earl
