Originally Posted by 05tahoeLT
I believe it to be an automatic climate control, digital display, dual controls for passenger, you just set the temperature and it sets the blower speed for you, although you can crank the blower motor up manually as well.
I would remove the blower motor and apply 12 volts to see if it works properly ,,,it most likely will ....then get some cash and buy a new hvac control module////...
with the manual it would most likely be the resistor/blower relay module cost of 20.oo aftermarket type ...
with the auto hvac this BLOWER is controlled by TOP SECRET GM ELECTRONICS....
