94 Camry TransVentura HiWay 06-15-2009, 06:25 PM Hello, 94 Camry with a 4 Cyl. Transmission will not shift properly. I believe it is running in fail safe. It won't hardly pull itself starting out unless I manually put it in 1st, then shift it to 2nd. Fluid is not burnt & it does not slip. It just won't shift normally. I know this is a ECT. I don't want to just start throwing solenoids on it ect. OBDI - got a code 71 on engine. That relates to the EGR Code 63 on the Trans. O/D light flashed a 6 3. Anybody know where I can get ECT Trans codes & diagnostic procedures? Or any other helpful suggestions would be appreciated! Thanks javatrooper 06-15-2009, 06:27 PM tranny codes in the manual posted on top. Just used it myself. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
