Ide Speed Controller Reading On Service Engine Lightgatorinsc 06-15-2009, 11:51 AM I have a 1998 Windstar and the light came on. I had the code read and it indicated an issue with the idle speed control but I didn't get the exact code. Does anyone know what possible problems this could indicate? Thanks. garync1 06-15-2009, 05:16 PM It maybe your idle air control valve.. You can first try to clean it.. If that does not work replace it with a motorcraft one.. gatorinsc 06-16-2009, 01:39 PM It maybe your idle air control valve.. You can first try to clean it.. If that does not work replace it with a motorcraft one.. Thanks for the reply. Is the Idle Air Control Valve a separate part from the Idle Speed Controller or the Idle Speed Control Actuator? glennet404 06-17-2009, 11:39 AM Hello- Yes - the idle speed control is a seperate unit. The general symptom of this problem is the inability of the engine to idle. It will start - but unless you have a foot on the gas pedal - it will stall out. You may want to get the exact code before you just start replacing parts. Good Luck Glenn Automotive Network, Inc., Copyright ©2012
