Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Silverado
Old 06-14-2009, 11:12 PM   #1
JOE RIV 1
JOE RIV 1 Normal reputation
tranny hard shift
I have a 04 2500 hd w 6.0 4l80e trans. it just started to shift hard into 2nd all other gears are fine.did a fluid change and its the same.no no dummy lite and no codes.Thanks for some input. joe riv
JOE RIV 1 is offline   Reply With Quote
Old 06-15-2009, 10:25 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: tranny hard shift
You need to get it on a transmission/engine capable scanner and read out transmission shift data and engine data.
Post back any codes from a good scanner check
MT
MT-2500 is online now   Reply With Quote
Old 06-15-2009, 03:09 PM   #3
JOE RIV 1
thanks for the responce.im trying to set the scan up with out getting taken.
Old 06-17-2009, 09:16 PM   #4
JOE RIV 1
had my gm buddy check it with his scan tool and nothing came up. all shift points are all good. now what? some times its good and sometimes when i give it gas it bangs hard.MORE HELP PLEASE!
Old 06-18-2009, 10:35 AM   #5
MT-2500
AF - Advisor
MT-2500's Avatar
It could be a engine running or a tramsmission problem.
When it gives you a hard shift is the time to ckeck it out.
A good engine/transmission capable scanner and a good tech/mechanic should be able to spot and show the problem.
Also it should be setting a code past present or history.
MT
Bookmarks
Google
Web AF
