car start and stalls not all the timebig white bufflo 06-14-2009, 09:31 PM :crying:2000 ford taurus car will start fine and run fine no codes present but some times stalls when put in gear i suspect fuel filter or pump i have 34 psi with key on and 36 to 38 when running what is the fuel pressure spec on this car :runaround: big white bufflo 06-17-2009, 07:20 PM this morning the car acted up about two mile from home car stalled restated the put it in gear gave it gas then it stalled again did this 3 time then remained running replaced fuel filter fuel psi is 38 to 39 and 34 at idle any ideas would be great 2000 dbl over head cam no codes no light shorod 06-17-2009, 11:34 PM Per the forum guidelines (http://www.automotiveforums.com/vbulletin/guidelines.html), please incorporate punctuation into your posts. It's difficult to read when it's not obvious where one thought stops and the next one starts. Key on, engine off fuel pressure should be between 45 and 56 psi. Key on, engine running should be 50-56 psi. Have you measured fuel pressure when the car starts and runs fine? It's not uncommon for a failing fuel pump to exhibit failing symptoms as the pump heats up. Also, since the fuel pump is a DC motor located in the fuel tank, the fuel acts as a heat sink for the fuel pump. Often failing pumps will work better on a full tank of fuel than on a low tank. Of course they will certainly fail when the tank is over half full since they get pretty heavy at that point. ;) -Rod big white bufflo 06-18-2009, 07:04 AM ok i thought the numbers were low so i went on auto zone they list 30 to 45 psi so i think i will tell my person she ned a fuel pump thanks for the help big white bufflo 06-30-2009, 07:47 AM sound to far fetch but person took car to repair shop they changed the intake gasket .car as been fine since Automotive Network, Inc., Copyright ©2012
